Oil pressure sensor wires
Old Feb 11, 2001 | 02:36 PM
Skip Howard
Guest
Posts: n/a
I'm in the process of trying to put the original oil pressure sensor back in and I can't find the wires! What color are they? I'm sure they were cut because EVERY other plug on the harness was cut off when I bought the car. I just want my gauge and choke back!
85T/A 305/QJ work in progress.
Old Feb 11, 2001 | 02:51 PM
Guest
Guest
Posts: n/a
If its a carbed car, it should just have one wire, a brown one from the driver side harness.
Old Feb 11, 2001 | 03:13 PM
Skip Howard
Guest
Posts: n/a
Really? The sensor that was in the oil port had two terminals. Now I'm starting to wonder just what engine I have in the car. I noticed that the AIR tubes in the exhaust manifold seemes to be in a different loation than the other Firebirds I've looked at. (the rear tubes are on the side, not the top). Also, the pre-heater tube thingy (technical term ) for for the air cleaner is on the passenger side, not the drivers side.
[This message has been edited by Skip Howard (edited February 11, 2001).]
Old Feb 11, 2001 | 03:21 PM
Guest
Guest
Posts: n/a
Sounds like you have mix+match there. Have fun
Theres a 2 wire sensor that was used on the FI cars in 85, it was for the fuel pump. There was a second sender that had one wire (brown) that was for the gauge.
Whats the 8th digit on the VIN?
Old Feb 11, 2001 | 03:26 PM
Skip Howard
Guest
Posts: n/a
I'll have to check the VIN when I get back home. (I'm on deployment for another month) I do know it's a VIN code H in the windsheild for the motor. There's also what seems to be a pretty large sensor with a single terminal down by the oil filter. Knowing the kid I bought it from, he probably put a truck motor in it or something. Who knows, maybe I'll get lucky and it's a 350!
89GTAOz
May 16, 2020 09:31 AM
9192camaro
16
Feb 3, 2019 12:21 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
