how much power opinions
Old Feb 27, 2004 | 08:11 PM
bigj85z-28's Avatar
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
Hey yall. I need some help gettin some approximate numbers for my new engine. I have neither a dyno nor software, so i figure you guys could help out. heres what im runnin...
82 z-28 with a bored out 305 equaling 311.6 cubic inches. Its got an edelbrock 650, victor jr single plane intake, roller cam specs- 316 duration at .475 lift for intake and exhaust, heads off of a 92 caprice cop car, heads have been cleaned up with minimal porting. compression is about 10:1. IM running a blaster 2 coil with MSD 6a ignition. I have headman headers going into a y pipe then 3 inches back to the flowmaster. Thanks for the input.
Justin
Old Feb 28, 2004 | 12:12 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
If you can double check your cam specs or maybe tell me what cam it is I'll check it on DD2000 for you.
Old Feb 28, 2004 | 12:17 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
With desktop dyno i got 315hp and 276tq. It be helpful if you had some info from the cam degreeing so i could enter the exact valve opening and closing points.
I think the duration you gave might be a little high. Are you sure thats the right number?I tried a cam with a less duration than yours and got much higher numbers. 370hp and 370tq.
Old Feb 29, 2004 | 03:19 PM
bigj85z-28's Avatar
Car: 79 z-28
yup those are the right numbers. that cam was in it when i got it. It was built to have decent gas mileage down low i suppose. Can you try the previous setup, but with a performer rpm, dual plane intake and a comp cams 280H? i just bought those this weekend. Hopefully that will get those numbers up a bit, and into a more usable rpm. Thanks
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thornburg
Aug 25, 2015 01:46 AM
sailtexas186548
Aug 24, 2015 10:11 PM
