atten..GMTECH
Old Feb 10, 2001 | 01:32 AM
hookin88formula's Avatar
atten..GMTECH
hey how are u i ws wondering if the cold air induction that u made for your car would work on my 88 formula bird that is tpi have u ever thought of how a person could hook that pipe up to the maf or dont u think it would work? well thanks for any info u would have!! thanks
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Feb 10, 2001 | 07:21 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You could easily adapt a MAF to my setup. You would just put the MAF at the snorkel, then use the same exhuast pipe I used and cut about 5" off the end, and get a piece of round rubber (you could find a used snorkel somewhere and cut it up) and use that to attach the pipe to the MAF, and use a similar cone filter.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 11, 2001 | 11:09 PM
what kindof cone did u use just one that would normally attach to the tb?? like the one in jegs? thanks
Old Feb 12, 2001 | 05:57 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
No, I think the one used on the TB is to oval to fit over the end of the pipe. I used the cone filter with a round, 3" rubber seal, like what is used on the rice cars It doesn't look ***** though, when its backed by a V8
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
