Air Valve Vibrating
Old Feb 12, 2001 | 09:57 PM
Neo's Avatar
Neo
Air Valve Vibrating
There is a black box above the right valve cover. I have been told it is called a Air valve, it sends hot air through the exhaust to finish burning the fumes.
Well it is vibrating badly. I increase the RPM, it increases the noise. It sounds really bad, The guy I talked to said it is not hurting anything but I still want to get rid of it. I can slightly push it towards the "center" of the engine and it stops vibrating. What can I do to stop this permeatly?
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Old Feb 12, 2001 | 10:28 PM
Vader's Avatar
Neo,
You are probably talking about the A.I.R. management valve. It should have a double spool valve and a couple of vacuum lines, and possibly a solenoid.
Does it look like this?
If so, that's the A.I.R. management valve. It controls the A.I.R. pump output to the exhaust manifold, cat converter, or vents to atmosphere. If it is rattling, it is probably loose on its stamped steel mounting.
There really should be nothing inside the valve that should rattle to the point where you can hear it. It is possible that one of the A.I.R. check valves is sticking open, causing the valve spool to pulsate, but that's a remote possibility.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 12, 2001 | 11:01 PM
Neo's Avatar
Neo
That is it, Vader thanks for the help! Tomorrow I will try to tighten it.
Old Feb 12, 2001 | 11:05 PM
Vader's Avatar
If tightening the mounting doesn't do it, you need to look at the check valves, but if pushing it over quiets it down, that should do it.
Later,
Vader
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
db057
Aug 22, 2015 08:17 PM
jackhammer
Aug 15, 2015 10:04 PM
