Bucking!!!
Old Mar 1, 2004 | 10:10 PM
88IrocTPI's Avatar
Car: 88 Iroc
Bucking!!!
hey guys,
My car seems to be bucking. Like when im driving down the road doing about 30 or 40, the car is in overdrive, the car seems to give quick little lunges like bucking. What could this be. I have all new tune up stuff, cap rotor, plugs, wires, all that stuff. I checked all of my wires and none seemed to be burned or anything.?????????
Old Mar 2, 2004 | 05:17 AM
ede's Avatar
ede
torque converter lock up, or unlocking
Old Mar 2, 2004 | 06:04 AM
cgb's Avatar
cgb
That's what I'd guess.
Crawl under the driver's side of the car.
Find the wire going to the side of your tranny to a plug. Unplug it and go for a ride. If it goes away, you know it's the Torque Converter Clutch locking up when it's not supposed to.
Old Mar 2, 2004 | 07:43 AM
88IrocTPI's Avatar
Car: 88 Iroc
is it the plug that looks like it has 4 little connections on it? it is the shape of a box right?
Old Mar 2, 2004 | 07:55 AM
88IrocTPI's Avatar
Car: 88 Iroc
i forgot to mention my tach needle twitches a little bit back and forth when it does the bucking!
Old Mar 2, 2004 | 09:21 AM
88IrocTPI's Avatar
Car: 88 Iroc
somebody please help, i need to fix this crap
Old Mar 2, 2004 | 09:48 AM
cgb's Avatar
cgb
yes....it's a SQUARE plug that had a clip on it. Plugs in on the driver's side.
If this cures it, you more than likely have a sticking / malfunctioning TCC solenoid inside the tranny.
It's very easy to replace, and you'll need to change the fluid and filter at the same time ( in the tranny ) which your tranny probably needs anyway.
Old Mar 2, 2004 | 11:15 AM
88IrocTPI's Avatar
Car: 88 Iroc
so what this solenoid cause this surging problem and the tach twitching. the twitching only happens sometimes and i have noticed that it seems to buck very very slightly at cruising speeds on the highway also
Old Mar 2, 2004 | 12:23 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My winter car use to buck alot, turned out to be the tps
Old Mar 2, 2004 | 12:49 PM
cgb's Avatar
cgb
Okay...
The TCC solenoid "locks up" the torque converter clutch. This results in LESS RPM's when cruising. In a functioning 7004R with TCC, you drive down the road, at say 60mph in OD....keeping your foot on the gas, tap the brake pedal..you'll notice the RPM's INCREASE when you do..that's the TCC unlocking through a switch wired to the break pedal.
It COULD be something else..but since unplugging the TCC wiring is FREE, and will tell you right away if that's the problem....
Old Mar 2, 2004 | 01:36 PM
88IrocTPI's Avatar
Car: 88 Iroc
thanx alot guys, i guess i will try unplugging that sensor and see what happens, i will keep u guys posted.
69GTOby
Apr 18, 2016 02:34 PM
BrianI
Oct 3, 2015 12:57 PM
Giocio
Oct 1, 2015 12:20 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
Damon
Sep 26, 2015 04:29 PM
