Bushed Rods or Pressed Fit????
Old Mar 2, 2004 | 01:24 PM
daddy33's Avatar
Car: '85 Camaro
ok, im upgrading my 350 to a 383 so right now im kinda confussed on picking rods. I have the stock ones on right now and want to get rid of the and get some 4340 forged ones. But i dont know if i need bushed or pressed fit. I have a '93 350 block with the original rods and kieth black pistons. Does it matter which ones i get? i Know the bushed ones cost a little more but will they both fit on my pistons or do i have to get a certain one? Im in need of some rods a.s.a.p. so your guys input will help out greatly. Thanks
Old Mar 2, 2004 | 01:33 PM
ede's Avatar
ede
if you get bushed rods you'll need floating pin pistons. it really depends on what pistons you have. 99% of the time you wouldn't want a floating piston.
Old Mar 2, 2004 | 01:44 PM
daddy33's Avatar
Car: '85 Camaro
so since i have the stock rods with the kieth black pistons, most likely those are pressed fit? Another words i should just stick with the pressed fit....
Old Mar 2, 2004 | 02:32 PM
ede's Avatar
ede
i put KBs in my 402 they are pressed but if i'd wanted they were set up to be floating.
Old Mar 2, 2004 | 02:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Stock rods are pressed (actually, shrunk) fit.
Most high-perf rods, such as would be made of 4340, would be bushed for floaters; but many can be had either way.
You can buy pistons set up for floating, but use them in a press-fit situation.
Most street applications would be fine with pressed.
Old Mar 2, 2004 | 02:52 PM
daddy33's Avatar
Car: '85 Camaro
ok sweet, thanks for the info im gonna order my set today then.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
theurge
Aug 21, 2015 12:46 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
