what cause vibration in steeringwheel when braking?
Old Feb 12, 2001 | 10:08 PM
chrisfrerick's Avatar
my steering wheel vibrates when i brake what is causing this?
Old Feb 12, 2001 | 10:19 PM
Vader's Avatar
CF,
Likely it's a hard spot in a rotor or rotor warpage. Either condition is ususally caused by overheated brakes, and sometimes by defective rotor castings, but not usually.
You can have the rotors resurfaced, but the condition will return quickly if the cause is hard spots. It's almost as inexpensive to replace the rotors, since aftermarket rotors can cost as little as $30.00 each, and will solve the problem permanently.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 12, 2001 | 11:52 PM
Hulk0202's Avatar
Of course Vader is correct. I had the same problem and after I put new rotors on it stopped. While your down there, you mine as well replace your calipers. They're only $10 each, and there a snap to change.
Old Feb 13, 2001 | 09:51 AM
Steve89GTA's Avatar
$10???? that's it!?! I feel stupid for not changing them last november when I did the rest of the brake system. Then again, up here in Canada they're probably 20 times that price.
89 GTA G92
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
Crane Ignition
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Feb 13, 2001 | 11:27 AM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Steve89GTA:
</font>
Probably LOL!
It varies around here. Anywhere from about 15-up. They used to be about 80 a few years ago before the prices dropped. As for 10 dollars... I dunno if I wanna make a 20 dollar bet I wont run into the car in front of me.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
