why is it when i smash down my gas pedal at 25mph, my car goes nowhere?
Old Feb 13, 2001 | 01:08 PM
rondubbs's Avatar
its so sluggish to shift.. i had the plenum off for a while so do you guys think the TV cable needs to be adjusted? i smash down the gas and it dosent move like i want it to,, it slowly accelerated instead of snappy head jerking accelerating.. what do you guys think?????/
1988 GTA Trans Am 350tpi: 44k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, flux capasitor
Old Feb 13, 2001 | 04:08 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
you got to take the e-brake off too buddy
just kidding, ya id check your TV cable. that could be messing ya up. also make sure all your sensors and stuff are working ok. Are u getting any SES lights? I dont know if a jacked up MAF or O2 sensor would cause that kinda problem or not, but it might be worth checking. Id start with the TV cable first though.
Old Feb 13, 2001 | 04:45 PM
rondubbs's Avatar
no ses light and sensors are new , ill have to check the e brake
1992 Trans Am
May 10, 2023 07:19 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
