NOx levels high
Old Feb 13, 2001 | 08:18 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
NOx levels high
I had my new 86 TA emission tested and it had high NOx levels. I've heard running to lean will cause high NOx. Anything else that might be causing it? If the car had an aftermarket open element air cleaner on it, would it help if i through a more restrictive stock air cleaner back on it?
85 Z28
13.1@104
94 TA GT
Old Feb 13, 2001 | 09:59 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yes. Lean running, lack of EGR, and detonation caused by carbon buildup causing hotspots in the cumbustion chambers. Try running some water through the carb. Check your EGR (You might be able to push up from underneath {Unless TPI}) and make sure vacuum lines are hooked up. Otherwise it's a fueling prob.
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
mfp189
Sep 27, 2015 09:25 AM
