Ignition Coil and Fuel Pump Wiring
Old Feb 13, 2001 | 09:25 PM
LmpBzkt's Avatar
I am in the process of switching from TPI to a carburetor, but when I went to hook up my ignition coil, I put a test light to the hotwire that went to my ignition coil before and there is no power when I try to crank the car. The same thing is happening with the wire that goes to my fuel pump. I was told that the wires for the ignition coil and fuel pump should both still work after removing the computer, but they are not. What could be causing this, and am I going to have to rewire my coil and fuel pump?
Old Feb 13, 2001 | 09:32 PM
Vader's Avatar
Fred,
If you remove the ECM, the fuel pump relay won't energize (no power to the fuel pump). The distributor might not get power if the EST is out of the circuit, so that could explain the problem. Is the car an '88 or newer?
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 14, 2001 | 03:57 PM
LmpBzkt's Avatar
No it is a 1986
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
