help it overheated!
Old Feb 14, 2001 | 04:15 PM
JayZ28's Avatar
help it overheated!
I dropped my friend of at home after work and I was in front of his house with the car in park idle at 1000 rpms and it blew the cap of the coolant overflow tank and was steaming like a ****. whats the deal?
Also my oil pressure unit was reading really low when it happened(like 10-15 psi, normal is 20-30).
speed is a good thing,
more speed is a better thing
Old Feb 14, 2001 | 06:07 PM
Dumperbird's Avatar
Car: 87 Formula Firebird/ 84 Trans Am
Engine: 305 / 305 H.O.
Transmission: 700 argh 4 / same
Few things you could check to find out what has happened. 1st thing I would do is check and see if your fan still works. (if the engine's cold turn on the A/C) If it comes on check for anly leaks at the water pump. There are pressure relief valves that will go if the pump goes bad. If neither show signs of wrong doing, let the engine warm up and watch to see if the fan comes on to cool things down. If that's ok check your thermostat and make sure that it didn't get stuck.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
