stripped thread
Old Feb 13, 2001 | 04:13 PM
v6-3.1's Avatar
stripped thread
A couple of days ago the threads that connect the tranny crossmember to the frame stripped. how do I fix this problem .
(1990 camaro 3.1L v6)
Old Feb 13, 2001 | 05:55 PM
The ODB's Avatar
The best solution I can think of right now would be to cut an access hole in the side of the frame, drill out the stripped hole and use a larger sized nut & bolt combination with hardened washers on both sides.
good luck
ODB
Old Feb 13, 2001 | 09:11 PM
v6-3.1's Avatar
anyone else with other options
Old Feb 13, 2001 | 09:24 PM
Vader's Avatar
V6,
If you have a clear access, you can drill, retap, and stake in a thread insert to the weld nut in the subframe channel. The steel thread inserts with staking pins are fairly substantial.
Another option would be to tap to the next size bolt (possible metric), enlarge the clearance hole in the crossmember, and use a larger bolt.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 14, 2001 | 01:59 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i ran with mine like that for a while...no probs for a while...then it felt like the mount was broken...the tranny would thump when i gunned it. you could try thread repair kits....or tap it like vader said. but the thread repair kit is temporary and only has the strength of stage 5. luckily i got a different rebuilt tranny...so the thread thing was no problem.
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Feb 14, 2001 | 06:53 PM
gruveb's Avatar
Car: 1989 IROC-1
To fix it right you'll have to do like several people have suggested. Tap, drill and thread for the next larger size.
Linson
Sep 21, 2015 01:08 PM
gta892000
Sep 16, 2015 12:37 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Amillionoh7
Sep 5, 2015 11:44 PM
