anyone running Pro Toplines with a roller cam?
Car: '87 Camaro LT
Engine: 355 L98
what length pushrods did you use? i put my heads on and the stock length (7.195") pushrods are too short, the rockers hit the edge of the spring retainers. a guy from the shop where i got my heads came over and took a look and said i only need .100" longer. what's everyone else using?
Don't guess....
Go buy / borrow / beg / steal a pushrod length checker...
I've used this one before
http://www.powerhouseproducts.com/st...LENGTHCHECKERS
Car: 4
Engine: 6
Transmission: 5
Doesn't matter what everyone else is using. First off, theirs might not be right either; and second, they may or may not have the same block deck height, head gasket, cam, and rockers that you have.
The ONLY way to get it really right is to check YOUR ENGINE with a variable pushrod, AFTER it's been built, as I've posted for you before.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
