Question?!!?! Help Please!
Old Mar 4, 2004 | 05:49 PM
freestylin's Avatar
I've asked this before and still whondering if anyone can help me i got a 87 v6 2.8L firebird and was just whondering if anyone knew what this noise is its a knockingbanging noise coming from the engine when i hit the gas i checked the oil and everythin its all good anyone know what this could be?
could it be reving my engine to much?
Old Mar 4, 2004 | 06:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like pinging.
Ignition timing advanced too far, or EGR valve not operating properly.
Old Mar 4, 2004 | 06:22 PM
freestylin's Avatar
it was fine but then i revd it alot and drove it and then it started makin that noise
Old Mar 5, 2004 | 09:51 AM
five7kid's Avatar
Need a better description, then, of "knockingbanging noise coming from the engine when i hit the gas".
Rod bearings will tend to knock at any speed. Main bearings you may not hear at idle, but is a very hard knocking noise. Piston wrist pin or skirt slap tends to have a two-toned note to it (knocka-knocka-knocka rather than knock-knock-knock). Loose torque converter may require more RPMs to hear, but can sound like it's coming from the engine. Valve train tends to be more of a tap than knock.
If it started after a period of abuse, most likely you ruined something internal to the engine.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
