sputtering every now and then
Old Mar 5, 2004 | 08:11 AM
p0rk's Avatar
Car: 87 firebird
Engine: 305 tbi
Transmission: 5spd
every now and then (once a month or so) ill shut off my 87bird (305 tbi) and she'll just keep sputtering for a minute. why the hell does this happen?
Old Mar 5, 2004 | 06:03 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Sounds like your timing is not set right.
Old Mar 5, 2004 | 09:26 PM
p0rk's Avatar
Car: 87 firebird
Engine: 305 tbi
Transmission: 5spd
damn, thanks
Old Mar 5, 2004 | 10:12 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
I've seen bad gas do that too.
My dad use to have an old 83 fullsize chevy that if filled with 87 octane, it would diesel for about 5-6 seconds. I think it was a combo of octane and timing. I always gave him hell for it
Old Mar 5, 2004 | 10:30 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
this is called dieseling. it happens when the fuel still in the manifold hits hotspots on the head/piston. you can usually cure it by using a higher octane. I'd suggest running a carb/FI cleaner addative in your tank to see if that helps too
db057
Apr 28, 2019 07:45 AM
Andrew6.688
Dec 13, 2015 10:59 AM
TBICamaro
Jan 2, 2001 10:19 AM
84Berlinetta305
Jan 1, 2001 04:44 PM
Locry
Dec 28, 2000 11:46 PM
