intermitent sputtering in idle...wtf?
Old Dec 28, 2000 | 12:51 PM
Locry's Avatar
what could it be? the car runs fine...starts easily and idles ok, except for the occasional sputter at the exhaust... it occurs in regular intervals, like every 2-3 seconds at arnd 500 rpm... the tach also fluctuates with the sputtering...wtf?
oh yeah...it's a carbed 350...
[This message has been edited by Locry (edited December 28, 2000).]
Old Dec 28, 2000 | 01:57 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Need more detail. Sounds like the air/fuel mix is off.
Old Dec 28, 2000 | 09:16 PM
Locry's Avatar
ok... what do you need to know?...
aside from being carbed it has a dual point distributor..
Old Dec 28, 2000 | 10:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What kind of carb?
If it's a Q-Jet, it might be the plugs in the bottom of the fuel bowl under the primary jets leaking gas into the intake like they always do.
Old Dec 28, 2000 | 11:46 PM
Vader's Avatar
Locry,
What is your cam profile? A stock cam should allow a fairly smooth idle, but more overlap will definitely cause some lope and unsteady idle.
Where is the base timing? Any other symptoms, like smoke, overheating, etc?
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
db057
Apr 28, 2019 07:45 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Mark A Shields
Jul 25, 2001 09:39 AM
TBICamaro
Jan 2, 2001 10:19 AM
84Berlinetta305
Jan 1, 2001 04:44 PM
