Smog pump delete question...
Old Feb 14, 2001 | 05:36 PM
Dan87IROC-Z's Avatar
To do a smog pump "delete" you just take off the belt that goes from the smog pump to the crank, right?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 14, 2001 | 06:08 PM
gruveb's Avatar
Car: 1989 IROC-1
You can do just that. However, if you ever have to pass an emissions test, having the smog pump disconnected will burn up a lot of the check valves.
If you have to pass the test, better leave it alone.
If you don't and you want to get rid of all of that junk that gets in the way of even checking your oil, do it to it. I did, no problem. Search the archives and you'll find all of the steps needed.
Old Feb 15, 2001 | 02:01 AM
Thanks man!
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
