cutting seats for larger valves...
Old Mar 5, 2004 | 02:47 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Do machinists cut in iron head's material for larger valves? Or do they install new seats ("rings")? I know that seats are induction hardened in newer heads, but is this hardened area deep enough for cutting, for example, Vortec's intake seat for 2.02" valve?
Old Mar 5, 2004 | 08:35 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Im pretty sure they cut the old ones out and put new ones in. I dont know if the seats are pressed in or what but when working at the engine shop I remember alot of heads getting the seats cut out.
Old Mar 6, 2004 | 08:22 AM
Vader's Avatar
You mean like this?
Those are simply cut into the iron. There are no pressed-in seat inserts. If you're really concerned, you can flame- or induction harden the seats to crystalize the surface after machining, but it really isn't necessary. A good machinist should be able to tell by chip flow and cutter chatter whether the surface hardening has been cut through completely. Usually, opening for 2.02/1.60 valves isn't a problem in later iron heads. Early heads may not have had hardened seats at all.
Old Mar 6, 2004 | 08:49 AM
z_power's Avatar
Car: '89 GTA
Thank you
Vader: my curiosity led me to Budge Industries website, can't see any of your cars there; do you have any secret pics or secret cars?
Mike
Old Mar 6, 2004 | 05:07 PM
Vader's Avatar
Originally posted by z_power
Thank you
Mike
Of course you cannot see any of the cars - they're all under covers.
Old Mar 6, 2004 | 05:38 PM
z_power's Avatar
Car: '89 GTA
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
machinist21
Sep 5, 2015 03:03 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
Formula_88AE
Sep 3, 2015 01:47 PM
mrdevontay
Sep 2, 2015 08:04 PM
