Help - 9 Amps, and no fans?
Background - 89 camaro irocz, auto, tpi
Few weeks back, some ******* rips out cd player, rips out negative battery terminal, which I had to screw back in at 2am. Next thing I know, my fans don't come on anymore. Luckily I have a toggle switch, but they don't come on by themselves anymore? Any ideas?
Next problem, just a week ago, I notice instead of usually running 13-15 amps, It's running 12 and sometimes as low as 10. Battery is charging fine. Alternator just replaced today and still no change.
PLEASE HELP
__________________
www.laynethrasher.com
89 IrocZ
T Tops
700 R4 Auto Rebuilt
K/N Air Filters
Fan Switch
Decent Stereo System
Lots of Blood, Money, Tears
PLEASE HELP
__________________
89 IrocZ
T Tops
700 R4 Auto Rebuilt
K/N Air Filters
Fan Switch
Did you mean "9 volts"? If so, you need to verify the dash gauge with a separate voltmeter connected at the battery or alternator output stud. If your voltage is truly low, you need to start checking into the alternator, field wiring harness, and grounds.
It's reading 10 volts usually, but pep boys get 14 from the alternator and say the gauge is off. Also, I just replaced the fan switch and relay but still no fans?
