codes 42 & 43
Old Feb 16, 2001 | 08:56 AM
ShadowChild's Avatar
codes 42 & 43
electronic spark timing and electronic spark control. driving home from work today about 5 miles from being home cruising right along then all of a sudden i lose alot of power and the check engine light came on. made it a few miles to a little store where i stopped since i was overheating from the loss of power and i dont have my fans hooked up. sat there for a while waiting for it to cool down then started up and drove home. wasnt as bad then. yesterday i changed my ingnition control module and it seemed to be running great. oh and after i stopped i popped the hood to make sure there wasnt a fire and my drivers side manifold was glowing. any suggestions what to do? other than changing it over to a carb setup. that will come in the months to follow.
Old Feb 16, 2001 | 11:22 AM
snakeskinner's Avatar
42 could have been set if you set the timing any time recently. it sets when you unplug the bypass. as for the 43, could be a number of things. Knock sensor, wiring, EST module (yellow module near ECM), ECM, Prom or distributor related parts. I'd start by erasing both codes and driving it till the light appears. then check and see what code you get and find a diagnostics chart for that code and follow it.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old Feb 16, 2001 | 11:49 AM
i have never even touched the timing. this has happened once before but after awhile it went away. seemed to only do it when i put it to the floor. i got the timing error once a few weeks ago after i first played with the control module but after i shut it off and started up again it was fine.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
