Cam for toyota 2.4L engine!
I'm looking on buying a 91 4runner. It only has the 4cyl 2.4 engine. It can hardly pull its weight, anyway it's more fun than driving a Mazda 323. I'm gonna have it cheap cause the engine has 281000 kms on it. I'm gonna be rebuilding it but I need to know if there is any company that make some bigger cams for those engines..
Thanks,
Nik
Thanks,
Nik
Car: yep
Engine: uhuh
Transmission: sure does
There are aftermarket companies that offer cams, pistons,etc. for these.
I just can't think of the names..
I would call a local machine shop and ask them.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Do a search for LC Engineering. They do cool mod stuff and turbochagers for Toyota's,
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
found the link for you.
http://www.lcengineering.com/
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
