83 TA starting problems
Old Feb 13, 2001 | 09:52 AM
TA76's Avatar
Hi, I've just finished installing a new cam, intake, carb (standard Q-jet) and standard HEI on my 83 TA LG4 5spd (all computer stuff is gone). I cranked it up in the garage the other night and it seemed to run fine but I only let it idle for a few minutes as I didn't want to fill the garage up with fumes and give the wife a headache! So, I pulled her out Sunday and had a little trouble getting it started, I messed with the timing a bit and finally got it to crank but it would only run for 5-10 seconds then BAM! I'd get a backfire from the carb, once it even singed the hood insulation. I'm pretty new to this so I don't have a clue other than attempt to reset the timing, adjust the valves (again) and try over. Can anybody offer a wannabe hot rodder some advice?
Thanks...
Old Feb 16, 2001 | 08:00 AM
TA76's Avatar
Ummmm nobody even wants to take a stab at this one?
Old Feb 16, 2001 | 09:23 AM
Enkil's Avatar
Have you made any adjustments to the carb itself?
I rebuilt a carb on my 85 z28 once and didn't have any of the tools needed to make all the necessary adjustments. I do believe that was one of the more ignorant things I've done.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Feb 16, 2001 | 09:55 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
When you removed the computer, did you swap to a Vacuum-advance style HEI distributor? the LG4 distributor has to have a computer to work properly. Also, you need a non-computer controlled Quadrajet carb. IF you run the computer carb without the computer, it will run rich and idle awful.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Feb 16, 2001 | 01:12 PM
TA76's Avatar
Thanks guys, I did replace the computer HEI with a standard type (Accel blueprint series) and the carb with a non-computer Edelbrock Performer Q-jet. Carb adjustments are a possibility I suppose.
Old Feb 16, 2001 | 05:03 PM
84FTA's Avatar
Your timing is too far advanced. Move the distrib clockwise (If I remember correctly). Carbs are rarely a source of backfire and when they are it's usually from extreme lean condition causing an enviroment that can combust gas within the manifold.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 Trans Am T-tops
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
[This message has been edited by 84FTA (edited February 16, 2001).]
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
