Vaccum Source for MAP sensor
Old Mar 9, 2004 | 04:59 PM
1993GMCPU's Avatar
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
I just wondered if it matter where this was connected on 3704 TBI Edelbrock manifold to pull vaccum or if base of TBI would matter?
I also have a plugged fitting in rear of manifold that I could use if it does matter.
Old Mar 9, 2004 | 10:15 PM
Vader's Avatar
Any sounce of full manifold vacuum should be fine. Just be sure you're not connecting it to a timed vacuum port on the carburetor.
Old Mar 10, 2004 | 09:13 AM
1993GMCPU's Avatar
Thanks-TBI vacuum is on back of TBI where we also had a manifold connection, I am just trying to make sure vacuum is good, SCR/DCR better then before with 76 cc heads with .020 removed and thinner gasket .015 to bump up H345NP40 pistons.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
racereese
Oct 10, 2015 09:39 PM
customblackbird
Oct 1, 2015 04:30 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
rjcme
Sep 5, 2015 01:23 PM
