BYPASSING VATS...PLEEZ HELP.
Car: 90 Camaro RS
Engine: 305 TBI
Ok im bypassing VATS. how do i know which resistor to use. i know all 15 different ohms ratings that are possible...got a couple of them...couldnt find too many...but how would i know anyways...i have a multimeter...but no key to test. can i test the wires? thanks.
Rick
if i cant bypass it...due to lack of correct resistor...can i completely bypass the lock cylinder and jump the starter??? i NEED to start this car today!!! NEED to. thanks
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Rick
Rick
Car: 91 Red Sled
A Moderator felt it unapropriate that I post info about a standard factory "security" option that is about as easy to bypass as a switch (duh). Sorry for the lack of respect but I'm in a bad mood, sorry.
, Jon (91 RS too many mods to list), getting new engine in summer
[This message has been edited by Vader (edited February 17, 2001).]
[This message has been edited by JPrevost (edited February 21, 2001).]
Car: 90 Camaro RS
Engine: 305 TBI
WITH THE ADJUSTABLE ONE...dont i have to wait 4 minutes between each one? also...where do i connect the resistor...to both wires?? (striped) or to one of them...or what?? do i neeed 2 resistors? or just one...if so which wires does it go between? thanks/.
BB,
Until there is an official position on VATS from the board/site master, please email a moderator for the details.
Sorry for any inconvenience, but there's not much else I can do at this point...
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Later,
Vader
Car: 90 Camaro RS
Engine: 305 TBI
V,
i saw the archives and the anguish i cause GlennL98GTA. i realize that it is somewhat of a security breach but this IS a help board for our cars. I havent received much help at all. I know the knowledge is out there but some are unwilling to share. if they really think someone is going to get all of the resistors, take apart the dash, and try out all the resistors for 2 hours....sheet...its taken me two days to figure it out....and steal our UNDER 5000 dollar value cars, when they can steal my neighbors 80,000 mercedes....then fine. But all they are doing is hurting me and others in need of help
