Has anyone drilled Vortec heads for older intake pattern?
Old Feb 16, 2001 | 01:18 PM
Zgirl's Avatar
I've seen Vortec heads advertised with redrilled intake patterns, but I'm not sure if there's enough thickness to support the threads. Does anyone have any experience with this? I'm new here so excuse me if this has been covered a gazillion times.
Old Feb 16, 2001 | 05:49 PM
CrazyRob75's Avatar
Welcome! don't forget you can also grind the intake bolt holes to different angles.
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Old Feb 16, 2001 | 10:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Just helped a buddy yesterday on his Holley Street Dominator intake, to elongate the holes to match his Vortecs.
We needed to do some porting on the top of the intake runners on the Holley to match the Vortecs, and also had to open the sides of the intake on the heads to match the holley..I really don't like the flow path that we achieved..sorta like having a "bubble" in the line, so to speak, but it will still be much better than an abrupt transition from the intake to the heads.
I've heard of some places that filled the original holes and redrilled, but that idea didn't light my fire much.
Old Feb 17, 2001 | 10:57 AM
valu8or's Avatar
I received my Vortec heads from Pace with the older holes already drilled and tapped. There appears to be good threads and support for this mod. I used the Edelbrock Performer Vortec manifold (2116) and had no need for the older holes. I had to buy plugs for them as they do go into the water jackets and water was pouring into my new motor. I did some research before I purchased the heads and found out the runners do not line up very well and any horsepower gains might be lost due to this. Good Luck.
1986 IROC
New Crate 350 w/Vortec Heads, Edelbrock 2116 Vortec Manifold, Edelbrock Performer 2102 Cam, Edelbrock 1406 carb, Hedman shorty headers, Flowmaster Catback, Rebuilt 700r4 w/vette servo, etc..
Old Feb 17, 2001 | 11:26 AM
GOLD85's Avatar
i heard that the redriled vortec heads dont have enough materal in the threads, and are very seceptable to striping.
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
Old Feb 17, 2001 | 02:06 PM
CamaroZ_85's Avatar
you say the runners dont line up very well.....but thats when using an older style intake with vortec heads i assume?????
Old Feb 17, 2001 | 06:11 PM
jeff88convertible's Avatar
Just replaced oem heads with vortech ($485) I bought these heads nov. 2000. I was waiting for gm to put out new manifold for t.b.i. to match up with vortech heads. Purchased intake last week ($325) and installed thursday with help from a friend. I will tell you this we took are time removed old induction and heads and finished that night. Pre-lubed valves and started next afternoon. I heard what i thought was lashing but was break in point. ran it for an hour. I will tell you this I CANT WAIT TO EAT UP SOME STANGS COME SPRING!!!
[This message has been edited by jeff88convertible (edited February 17, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
