cam removal ?
Old Mar 9, 2004 | 08:36 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
cam removal ?
Is there a trick to the condensor I should know about? Can you move it aside or do I remove it?
Old Mar 10, 2004 | 07:24 AM
Engine: 5.8
Old Mar 10, 2004 | 08:04 AM
ede's Avatar
ede
never done an in car cam swap with a thirdgen, but if it were me i'd do everything i could to not remove the condenser, especially if it has r12 in it.
Old Mar 10, 2004 | 08:24 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Its been a while, but I am pretty sure we left my buddie's condencer in when we did his swap. just pushed it out of the way a little.
Old Mar 10, 2004 | 09:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is a bolt on the passenger side fraimrail. Unlbolt it and you will be able to swivel the AC condensor out of the way. The bolt is holding some hard lines down and when you remove it they are free to move.
Frozer!!!
Jan 19, 2024 04:55 PM
anesthes
Mar 10, 2016 10:35 PM
theshackle
Aug 22, 2015 06:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
