Lifter Question...
Old Mar 10, 2004 | 12:54 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
Lifter Question...
im rebuilding my 350, so i put a bigger cam and ported my heads out... i wanted to ask if its ok to stick with the stock lifters, or do i need to get new lifters for my cam? i know it would be better to get new ones, but if it would still be OK to use my stock ones, i'd rather do that since i know money doesnt grow on trees like i wish it would lol
Old Mar 10, 2004 | 01:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What type of lifters are they? If they are flat tappets, you should replace them because they wear out due to the friction between the lifter face and the lobe.
If they are a roller profile, they can be reused. Obviously the roller takes up much of the friction so they dont wear out like flat tappets.
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I would assume Hydro Roller b/c its a 90 5.7 right?
How many miles are on them?
Obviously it would be better to use new ones, but like you said money is an issue sometimes. I know it is for me. You could put them back in, but be prepared to replace them at some point. The added lift of the new cam, and the added spring pressure will not act kindly on the older lifters...
Old Mar 10, 2004 | 01:37 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
exactly 100k on the lifters... wish i had the flow for newer ones, but i dont so *** it... got other things i need to waste my money on in the rebuild
yeah, it's a 1990 5.7
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
