vacuum leaks??
Old Mar 10, 2004 | 05:43 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
vacuum leaks??
vacuum leaks seem to do alot of bad, i dont think i have a leak but would like to check just so i no 4 sure. whats the best way to make sure?? also how do u check to see if your intake manifold is leaking??
Old Mar 10, 2004 | 08:07 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
take a can of starting fluid and go under the hood while the motor is running. Start spraying around the runners, plenum, intake, TB, wherever there COULD be a leak. If you hear the engine revs increase when you spray in a certain spot, there's a leak. If the rev's don't ever increase no matter where you spray, no leaky leaky. You can use anything flammable. Propane works well and leaves no moisture, brake clean works too b/c it's real flammable and dries quickly.
Old May 4, 2004 | 10:03 AM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
Could any of this damage un-clearcoated polished alum. mainly my plenum and runners?
Old May 4, 2004 | 08:13 PM
rezinn's Avatar
Starting fluid isn't going to hurt aluminum.
FormulasOnly
Jul 23, 2018 08:47 AM
bbsr72
Apr 2, 2016 09:12 AM
jrdturbo
Mar 31, 2016 02:58 PM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
