power brake question
Car: 91 camaro rs
Engine: 355
I just finished my engine swap and the power brake vacuum line brackets and stuff don't fit. Can I just run a vacuum line directly from the booster to the vacuum port on my holley carb?
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
better than nothing, right?
an optimal fitting would be a bigass one on the intake manifold. if you dont have one, there should be one on the carb
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
Every single intake I have ever seen, or installed had a port for the brakes. It might be a size smaller, but its still there. Unless it is an intake from an older car that didn't come with power brakes
Car: 91 camaro rs
Engine: 355
I've got an edelbrock rpm air gap intake manifold and a holley street avenger 670 carb...there is a vacuum port for power brake on the carb. Can I run a vacuum line directly from there to the booster?
Transmission: 4L80E/4L80E
The factory tapped the power brakes from the back of the carb base. However, they also had a nipple on the front for the PCV.
You don't want to run the PCV off of a runner source. You want it spread evenly across the cylinders. However, the power brake booster doesn't have a constant flow, so tapping it off a runner is okay. And, you don't want to try to run both the PCV and power booster off the same source.
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Just run the booster off the port on the carb. It works fine that way. Besides, if you have a double pumper holley the back bowl covers up the vacuum port on some intakes.
