seized engine ? help please...
Old Feb 17, 2001 | 11:32 PM
91camaroRS's Avatar
ok got a new starter, charged batery, and oil has some gritty stuff on it and the engine will NOT turn over. ?? is it what i think it is and is there another way of fixing it than a rebuild ??
Old Feb 18, 2001 | 12:26 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Did it just stop running??
What makes you think its siezed.??
Can you turn the engine over by turning the crankshaft manually??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited February 17, 2001).]
Old Feb 18, 2001 | 12:44 AM
91camaroRS's Avatar
yea it just stopped. how would i go about cranking it manually ?
Old Feb 18, 2001 | 12:50 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Put a socket on the crankshaft bolt and turn it. (This is easier if you remove the plugs.)
If the car is an automatic, you can remove the flexplate cover and turn the engine with a flywheel tool.
If its a stick and you are trying to turn the engine, make sure its out of gear.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited February 18, 2001).]
Old Feb 18, 2001 | 06:14 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
What do you mean by gritty stuff in the oil? Like metal shavings? if theres metal shavings in your oil, you probalby spun a bearing.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Feb 18, 2001 | 01:34 PM
91camaroRS's Avatar
ok lets just say there was barely any oil cause you oil pan was all jacked up.....
Old Feb 18, 2001 | 10:26 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by 91camaroRS:
ok lets just say there was barely any oil cause you oil pan was all jacked up..... </font>
Was it ventalated??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
colton_carlson
Mar 8, 2019 12:21 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
