Help with paint removal
Old Feb 15, 2001 | 05:04 PM
evilho7810's Avatar
How hard is it to get paint off of runners? Will I have to paint over them? They are red right now and I don't want them to be red.
Old Feb 15, 2001 | 06:19 PM
Guest
Guest
Posts: n/a
Should be able to take the paint off with carb cleaner and not stain the aluminum.
Old Feb 16, 2001 | 03:25 AM
evilho7810's Avatar
No it's high temp engine enamel. I dont think thats strong enough. Does anyone know what they use for the clearcoat on wheels?
thanks.
Old Feb 16, 2001 | 08:32 AM
leirch's Avatar
I used Aircraft paint remover to get the clearcoat and powdercoat off my rims, you can get it at AutoZone. It may work and may not. Worth a shot maybe?
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Feb 19, 2001 | 04:30 AM
evilho7810's Avatar
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Wife'sCar
Aug 22, 2015 01:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
