Torque Specs on ARP head bolts
Old Mar 13, 2004 | 06:08 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
anyone know what these are supposed to be torqued down to? I had them on the car for less than 500 miles, and want to re-used them on a set of Sportsman IIs I'm about to put on, but I've thrown away the paper with the torque specs. All I can remember is that it was above the normal torque specs. Thanks.
Old Mar 13, 2004 | 06:53 PM
ede's Avatar
ede
check ARPs web site or use stock specs
Old Mar 13, 2004 | 07:16 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i just bolt on one of my new heads with new ARP head bolts. the paper says 60 lb-ft for aluminum heads.for cast heads it says 65 lb-ft with arp moly assembly lube or 85 lb-ft with 30wt motor oil
Old Mar 13, 2004 | 07:48 PM
k, thanks Heavy Chevy
Frozer!!!
Jan 19, 2024 04:55 PM
355tpipickup
Aug 25, 2015 12:54 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
