Buying an L98 motor in my 86 T/A, what should I look out for?
Old Feb 19, 2001 | 11:27 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am thinking about buying an L98 motor from an 89 Iroc. The motor is complete with all accessories. The car had an automatic tranny. My 86 T/A has a manual tranny, which I know won't last too long, but I'll take it easy until I can swap the tranny.
What are some of the things to look for on that motor, and will I have any problems with the ECM since the Iroc was an automatic car?
I don't know how many miles are on the motor yet. The guy wants $900 for it, is this a good price?
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Feb 19, 2001 | 10:27 PM
Vader's Avatar
Zepher,
You should try to get the seller to throw in teh ECM and harness with it. Your '86 has a cold start injector, but the '89 does not. Your '86 has one fan, ans the '89 was designed for two. You'll need a custom PROM for the 350, the knock sensor, and ESC unit. Your '86 has the coil in the distributor cap, and the '89 has a separate coil. Some of the wire on your harness might be short, leftover, or missing.
You'll need a custom PROM because the PROM in your ECM won't have teh correct fuel and spark curves for the 350, and the 350 PROM will have an output for the automatic's TCC. Unless you disable the SHIFT lamp, you'll have it on all the time when cruising down the road over 41 MPH at moderate throttle openings.
It can be done, but will involve a little work to do it correctly.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 20, 2001 | 01:01 AM
GOLD85's Avatar
i would go for it. are the T5s that weak they cant stand up to a 225 HP 350.ya know ive always wonder if the GM put a 5speed behind a 350 in a IROC or GTA if it would smoke a rustang. what do you guys think.
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
Frozer!!!
Jan 19, 2024 04:55 PM
lt500r55
Sep 1, 2021 01:30 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
TheExaminer
Aug 19, 2015 10:07 PM
86White_T/A305
Aug 17, 2015 12:16 AM
