LT1 ????
Old Feb 20, 2001 | 06:09 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
LT1 ????
I read that in the '93 Impala, the base engine was a 265 LT1. If so, then what other sizes did the LT1 come in? I know that for the '93 Camaros/Firebirds they had the 350, and also in the vettes.
What makes an LT1 what it is? In '93 the F-bodys had an iron block, and the vettes had aluminium blocks, but they both had the aluminium heads.
When did the LT1 first come in the Camaro/Firebirds?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 20, 2001 | 06:29 PM
leirch's Avatar
The LT1 came first in 93, the LT1 in the impala is a 350, the 265 you saw was probly HP?
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Feb 20, 2001 | 07:02 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
They did make a 4.3l V8 (265 c.i.) in the impalas and caprices. (I just put an Optispark unit in one today )
They look just like a LT1, but the LT1 is a 350.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited February 20, 2001).]
Old Feb 20, 2001 | 07:04 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
LT1 came out in '92 on 'vettes and '93 in F-bodies. The Caprice 4.3 (wanna be LT1) would be an L99.
George P. Lara
1984 "L69 A4"
Soon to be 357, T5, 3.70
1994 LT1 M6
SCCA, SCFB, SC3GFB
Old Feb 20, 2001 | 07:09 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
LT1s did not have aluminum blocks, L99s are trash and are easy to designate on a caprice by not having a P as the 8th digit.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
