Rich or Lean
Old Mar 16, 2004 | 08:08 PM
FastBack's Avatar
Car: 91' Firebird Formula WS6
Transmission: TH700R4
Rich or Lean
is there an easy way to tell if i am running air/ fuel rich or lean without getting a air to fuel ratio gauge in my car? there must be a way i just don't know about. and whats the easiest way to correct either of those? i figure you can just adjust how much fuel you are using right?
Old Mar 16, 2004 | 08:45 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
You can tell by the smell of the exhaust usually. Is your car carbed or fuel injected?
Old Mar 16, 2004 | 09:11 PM
FastBack's Avatar
fuel injected
Old Mar 16, 2004 | 09:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by FastBack
fuel injected
You need to data log and check out your BML's. That is the only accurate way to tell.
Old Mar 17, 2004 | 08:02 AM
FastBack's Avatar
how do i go about doing that?
i have heard that you can tell by the smell of the exhaust, how exactly does that work. i know it is probably not that accurate but i was just wondering how that worked.thanks guys
Old Mar 17, 2004 | 09:39 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well if your car has a cat than it is not very accurate. You car can still run rich even though it smells fine with a cat. That means the cat is doing its job and that you aren't so rich that it is not keeping up.
Old Mar 17, 2004 | 11:11 AM
FastBack's Avatar
what does it smell like if its running rich and i don't have a cat? like gas maybe?
Old Mar 17, 2004 | 11:33 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup
Old Mar 17, 2004 | 11:42 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
If its rich w/o a cat you will know when you start clawing at your eyes b/c they burn from the raw fuel coming out!!!
Old Mar 17, 2004 | 09:33 PM
Vader's Avatar
There is another method, but it is subject to the same variability and innaccuracy as the ECM data logger method. If the O² is being "fooled" by an air leak into the exhaust, or is weak or contaminated, reading data drom the ECM is useless. The only positive method is with a separate wideband oxygen sensor, either installed in the exhaust stream or as part of an exhaust gas analyzer.
If you have confidence in the integrity of your O² sensor, you can invoke the Field Service Mode through the ALDL, and reveal whether the ECM is trying to correct for a lean or rich condition. There is no means to quantify the degree of rich or lean exhaust gas, just to tell whther it is rich or lean.
Old Mar 18, 2004 | 02:12 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Your engine should be changing from slightly rich to slightly lean and back again. If it's not your O2 sensor is probably bad. I have an Auto xray scanner that tells me if my car is doing this. It's kind of an expensive tool ($175.00), but it does a lot other tests as well and it works on other GM cars and trucks up to 1994. I wouldn't want to work on my car without it.
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
