Additive
Old Feb 21, 2001 | 03:54 AM
Darrell's Avatar
Car: 1991 GTA
Engine: L98 350
Transmission: 4L60
Additive
Hey guys.....just curious on the product called Zmax. I know that the others like Duralube and Slick 50 are not good for the performance engines because of the teflon...but I was wondering if anybody tried Zmax and their opinions...Just curious because I just saw it on TV again and figured I would ask.
Old Feb 21, 2001 | 07:52 AM
Steve89GTA's Avatar
Don't.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Autometer Vac+Oil Temp
Old Feb 21, 2001 | 09:42 AM
ORION's Avatar
Personal note to you - avoid any additives to any performance engine if possible. If your having trouble with your engines performance, try adding BG 44X or GM Top Engine Cleaner to the fuel at fill-up. Give it a while to work, and check your fuel filter after your next fill up. Carbon can cause a lot of fouling and loss of performance. But as for other additives - We could say the cure can be worse than the disease!
sailtexas186548
Feb 17, 2017 03:07 PM
PurelyPMD
May 5, 2016 04:57 PM
blackz281le
Jan 11, 2016 07:51 AM
Giocio
Oct 1, 2015 12:20 PM
WhteRbt
Sep 21, 2015 09:48 AM
