okay i bought 416 heads but know
Old Mar 17, 2004 | 06:32 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
i bought 416 heads and know i hear that i have to drill out a spot so the intake can be bolted to the heads i thought that it was supposep to be a bolt on pair of heads.thanks ahead of time.
Old Mar 17, 2004 | 08:12 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Very close to bolt-ons.
The center two bolts on each side of the intake manifold changed angle in 1987. The last year for 416's was 1986. Elongating the bolt holes in your manifold, with a drill bit or rat tail file, is what's required to get it to fit the heads.
Old Mar 17, 2004 | 08:52 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
TB,
I put the 416 heads on my '92 Camaro. It's really not a big deal. You just have to take a drill and make the center bolt holes on your intake oval. That way the bolts can reach the holes.
Old Mar 17, 2004 | 01:40 PM
tbfirebird's Avatar
Engine: ??????????
k thanks just glad its nothing else also is there any type of good gasket like the best out there thqt i should get for the intake and heads?
tbfirebird's Avatar
Engine: ??????????
oh yeah how much of a difference where the heads over the stock tbi ones.
Old Mar 17, 2004 | 09:43 PM
Vader's Avatar
If you are planning to use your self aligning rockers, you would also want to enlarge the push rod guide holes to clear the push rods. While the heads are removed, you might do well to replace the rocker studs. 1.94" valves are a decent fit in '416 heads, too, if the lifts are not so high as to cause deck interference with the valves.
Old Mar 18, 2004 | 04:41 PM
azvolfan's Avatar
TB,
Well for me it is yet to be determined. I am actually running slower at the moment. I am currently doing for data logging and having a custom chip burned as to tie all of the mods togethere. So I am sure they flow better than the stock heads, but I have no proof as of yet.
86IROC112
Sep 7, 2015 01:37 PM
355tpipickup
Aug 25, 2015 12:54 AM
johanlindgren
Aug 16, 2015 12:16 AM
