compression vs. cylinder pressure
Old Mar 17, 2004 | 05:00 PM
84zeddd's Avatar
Can anyone give me a rough idea what 185psi on a compression
test might translate to in a compression ratio.(it only has a mild
cam in it)
Old Mar 17, 2004 | 06:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It doesn't. No way to tell.
Old Mar 17, 2004 | 08:38 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I'm nowhere near as good as RB, so I can't tell you either.
What I can tell you is 185 is a good cylinder pressure to run on the street with pump gas.
The target range, from what I've read and heard is 180-190 psi cranking pressure.
angel2794
Sep 8, 2015 06:22 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
