Car falls flat on face...then goes like hell?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have a 91 Formula with the LB9 305 motor. THe car is an automatic with a 2100 stall convertor, 4.11 gears and SLP 1 3/4" headers. Has a Flowmaster 3" system on it. Fuel pressure is set at 50 psi. Ignition consists of Accel 300+, MSD wires cap & rotor and Bosch Platinum plugs. Otherwise, the car is stock.
When the car launches, it bogs for a minute and then goes like hell and chirps the gears. What would cause a momentary bog and the such rapid acceleration?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
suddenly opening up the throttle body ont he tpi will cause the pressure to go to atmospheric (WOT). Sounds like the throttle response needs a little work.
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Would timing do this? If the car is in neutral and the throttle is revved, it stumbles and then sounds good. At the initial application of the thottle it stumbles though.
Since it has been a while since I have had a 305 in this car, could someone let me know where exactly all the vacuum lines go off of the plenum? I know the back one on the driver's side goes to the brake booster, but the rest are just guesses....please help!
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: Car falls flat on face...then goes like hell?
Car: '89 GMC Pickup
It did it when it was full and it does it now at around 1/2 tank. Why do you ask?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
That is a good point, but his happens while the car is idle in park and gets revved also.
Does anyone know if having the timing off a little will do this?
Thanks again guys
Steve
Thanks again guys
Steve
Car: '89 GMC Pickup
Another WAG; Maybe a flaky MAP sensor or vacuum line to the MAP? Flat spot in the TSP sensor?
There are of course many other reasons, including needing a PROM tuned for you engine, but I'm sure you've checked the obvious.
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
When I first got the car, the fuel pressure was set at 50 psi with the stock computer and the car ran really strong at 14.6.
I am thinking either a vacuum problem or a timing problem but am hoping someone can confirm this and/or give me an idea for the vacuum routing.
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Did you ever solve this? I have recently developed a simmilar problem. I have played with the timing and it made no difference. I'm actually starting to think my problem is the wires. They are so close to the headers that the number 8 wire has been known to smoke.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I have an entirely different motor, but mine stumbles when I spike the throttle too. It almost misfires and then revs up. But mine also hangs up twice after a rev before it falls back to idle. I suspect a bad TPS sensor, even though it's new...it might not be calibrated right.
If you figure this out, I'd love to know. I imagine the motors are similar enough that we could be having the same problem.
Car: 73 chevy truck
Engine: 406 11.6 comp 2.02 heads
Transmission: stock th350
im used to carbs but i think tuned port works the same way. to me it sounds like an accelator pump or on tuned port i think its called pump shot inrichment. cause when you mash the gas the atomospheric pressure changes and the engine need more fuel. any one know what im talking about?
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Could this possibly be a TPS problem?? Tyr taking a ohm meter and check for any dead spots on the TPS. Ya never know???
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Maybe the tps is simply out of adjustment. There is an idle voltage that is supposed to indicate the engine is at idle. If it is above this and the engine is idling, the engine will bog just as you said. It senses the rise in voltage and gives an extra shot of fuel, just like the accelerator pump on a carb. When the accelerator pump on a carb goes out it is flat then goes. I think the spec should be around .45 volts or something like that ( If someone could confirm this it would be great as I am looking at a book that only has CCC Quadrajet and TBI stuff, the voltage is the same for both of them so it should be the same for TPI). All you have to do is slightly loosen the allen head bolts then move the tps until it indicates the correct voltage, holding the tps in place, tighten the bolts back up. Hopefully this adjustment works. I had a friend with a 1997 LT1 camaro that did the same thing. Turned out it was the TPS adjustment, just can't remember the spec for it right now probably .45 volts just like the other GM ecms.
novaderrik
Aug 10, 2015 12:44 PM
