Listen to this IAC problem. I need help.
Old Feb 21, 2001 | 09:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Here I go. I grounded it out for 30 secs, pulled the IAC connector off, unplugged paperclip, fireed it up and I cant get it to go beloe 1000 RPMS the little screw isnt even touching the handle anymore. So i said hmm so i go about to where the screw would hit the handle and turn the car off. I plug IAC back in and fire it up and wham it idels at 550. So i come back tomorrow and fire it up and it starts but stays at 500 RPMS with in a second its doesnt even go to 1200-1000-800-and down to 500 it starts at 500. Whats wrong?
Old Feb 21, 2001 | 09:19 PM
Vader's Avatar
Mkos,
It sounds like maybe the throttle shaft is sticking in the body or the throttle plates are binding. This can cause the throttle to "park" in various positions above normal idle position. Check the edges of the throttle plates and inspect the bores for wear and polishing where the plates may have been touching. Make sure the shaft has no vertical play or free movement when the throttle is open.
Another possibility is that the IAC is sticking, and could use a thorough cleaning (while out of the throttle body and with the pintle removed).
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 21, 2001 | 10:40 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
if you take your IAC out and clean it, make sure you dont use carb cleaner on it, use throttle body cleaner(dont ever ever use carb cleaner on a fulie car, the carb cleaner is to harsh, and can knock out your TPS or IAC)when you clean it, make sure you keep the part with the little spring pointed down, if cleaner runs up inside it, its possible that it will ruin the sensor. just make sure you dont turn it upside down, clean it good, blow it out. also, on some IAC's, after you replace them, and some you clean, you are supposed to drive 4 miles at 40 mph to "reset" the IAC. just my .02
Wide Open Till You See God...Then Brake
Old Feb 22, 2001 | 08:05 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Ive heard about the 4 miles at 40 from my GM tech down the street. Also the TB is brand new. Its a 52 BBK. I'll try to clean it this weekend. Thanks
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Numbah-1
Oct 2, 2015 08:27 AM
thejimsterz28
Sep 30, 2015 08:52 PM
