Temp Gauge
Old Feb 21, 2001 | 12:04 PM
billyde's Avatar
Temp Gauge
Which temp sensor is the one linked to the temp gauge, the one in the block or the one in the intake manifold. My temp gauge has been pinned in the top position for over a year now. Thanks.
1984 Camaro Z-28 LG-4
Q-Jet, dual snorkel air intake, underdrive crank pulley, Hypertech Street chip, SLP y-pipe and 3" cat back with hi-flow converter, Edelbrock Performer intake,Accel ignition. Running better now.
Old Feb 21, 2001 | 12:11 PM
R.O.B.'s Avatar
The one on the block between cyliners 1 & 3.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 21, 2001 | 12:18 PM
billyde's Avatar
i must have the wrong one in there then. Replace it a while back hoping to fix the gauge. When I pulled it out, I saw it was the "button" type. The replacement I have is the "clip end" type. Guess i'll give the button one a try and see if that fixes it.
Old Feb 21, 2001 | 05:52 PM
HIX5000's Avatar
Are you sure the gauge isn't broke? I had a gauge that was pegged out. I replaced the gauge now it works fine.
Old Feb 21, 2001 | 06:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The connector will fit to either the blade style or the mushroom style. As long as it fits in the hole, and it's really a sender for a gauge and not the one for an idiot light, it should work; electrically they're all the same.
Pinned at the top means either a bad gauge, or the wire is shorted to ground somewhere. If the gauge is good it should come down at least sometimes when the key is off. If it never moves, get another cluster from the junkyard. It's about a 15 minute swap, very easy.
ICON Motorsports
Old Feb 22, 2001 | 08:27 AM
billyde's Avatar
Thanks. Sounds like that might be it. The temp gauge hasn't moved in over a year and I have replace both sensors.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
