Belt Tension Pain HELP!
Old Mar 18, 2004 | 08:38 PM
streetphase.com's Avatar
Car: 92 Camaro
Engine: 305tbi
$400 later I am one step away from driving my car. After putting in a new intake manifold and ditching the smog pump the last thing I need to do is hook up my serp belt. My car is a 92 305 with the belt tensioner, what torx will fit that? I tried a #50, to small and a #55 to big no one carries anything in between any other ways to get the belt on or what kind of tool is needed to remove the tension screw. Need help my car has been sitting for a week and I really need to get it back on the road...
Old Mar 18, 2004 | 09:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It should take the #50 torx bit. How loose is it that makes you think it is too small?
Old Mar 19, 2004 | 08:01 AM
Car: 92 Camaro
Engine: 305tbi
loose enough where when i turn it it just slips and is starting to strip the bolt
Old Mar 19, 2004 | 08:11 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Why do you need to loosen that torx screw to get the belt on?? Or are we talking about something else??
Old Mar 19, 2004 | 08:14 AM
thirdgen88's Avatar
Car: 1995 Corvette
Just put a 1/2" Ratchet in that little square hole on the tensioner arm and pull counter clockwise to release tension on the belt (it is spring loaded)... Just slap me if you're trying to do something else, but you said you were trying to get the belt on..
Old Mar 19, 2004 | 08:16 AM
thirdgen88's Avatar
Car: 1995 Corvette
Here's a picture:
Old Mar 19, 2004 | 08:59 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Thirdgen88 is right on!!!!! Do not start to remove any torx bits. You just need a breaker bar or a .5" ratchet without any attchments on it. It should take you 3 seconds to get the belt on.
Old Mar 19, 2004 | 11:46 AM
thirdgen88's Avatar
Car: 1995 Corvette
That's what makes the serpentine belt system on our cars so cool, is that its so easy!! :-D
Old Mar 19, 2004 | 11:56 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I mis-read his original post and thought he was taking the tensioner off. My bad!!!!!!. Also, there are some tensioners out there that take a 3/8" ratchet or breaker bar to release the tension. I have one on my car.
Old Mar 19, 2004 | 12:35 PM
Car: 92 Camaro
Engine: 305tbi
so this whole time i thought i had to remove the torx bolt to rotate it when thats all i had to do. Im goin out to try it now thanks so much for the help
Old Mar 20, 2004 | 04:38 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
I can picture him slapping himself on the head and saying "DUHHHHHHHHHHH"
Old Mar 21, 2004 | 09:27 AM
Car: 92 Camaro
Engine: 305tbi
well i got my belt on and it took me a whole 10seconds to do it man am I dumb. took me about 2hours of driving to hardware stores trying to find a torx bit to fit that was a pure waste of time and spent about $20 on stuff that never worked. well thank *** for these forums I was about to get my car towed to a shop.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
anesthes
Sep 30, 2015 07:48 AM
kitt23
Sep 26, 2015 07:48 PM
