fuel pump on it's way out?
Old Feb 21, 2001 | 10:53 PM
Jza's Avatar
Jza
The other night on the way home, at cruising speed on the bridge (of all places) the car briefly bogged several times intermittently, very much like when you go around a turn too fast on low fuel.
150k on 305TBI...
(I hope it's not the reason, 'cause the last thing I want to do is a fuel pump...)
Old Feb 22, 2001 | 12:03 AM
Jza's Avatar
Jza
BTW, fuel filter was replaced 20k - 30k miles ago.
What are the symtoms of a failing pump?
Old Feb 22, 2001 | 02:00 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Very likely, mine did the same thing...tried everything and still ended up changeing out fuel pump...might want to check fuel pressure just to make sure...
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
