ZZ4 cam questions for 355 L98
Old Feb 24, 2001 | 05:48 PM
peeon188's Avatar
My question is what rpm will my car shift out of 1st gear with this cam.
Will lt4 springs work with 1.50 rockers and fit my stock heads without machining.
Old Feb 24, 2001 | 05:55 PM
DSouthern's Avatar
I can't answer your rpm question, but on the valve springs you will have to machine the heads because the LT4 springs (do you mean LT4 hot cam springs) are larger diameter than the stock L98 springs.
Old Feb 24, 2001 | 06:12 PM
peeon188's Avatar
then what would be a good set of springs to use with the l98 heads and would accept the 510 lift of the zz4.
<font face="Verdana, Arial" size="2">Originally posted by peeon188:
</font>
lt500r55
Sep 1, 2021 01:30 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
