quick... EGR GASKET, CAN I MAKE ONE?
Old Mar 24, 2004 | 02:41 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
I am putting the Tpi back together, but don't have a egr gasket. I cleaned the surfaces, and have cut a new one out of heavy gauge cardboard. I am planning to
"black RTV" both sides. What do you think? I can't just get the "right one" here in Japan. thanks shawn
Old Mar 24, 2004 | 04:49 AM
ede's Avatar
ede
i think i'd buy some gasket material instead of carboard. both parts are a machines surface so sealer wouldn't be needed.
Old Mar 24, 2004 | 05:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Remember, there's exhasust ags there. Is your cardboard exhaust-gas-proof?
If not, I would suggest not using it. It would be worse than using nothing.
High-temp RTV and no gasket at all usually works OK at least for a few thousand miles, although you might need shorter bolts.
Old Mar 24, 2004 | 10:49 AM
RocZ57's Avatar
I found one at autozone for $3.
http://www.autozone.com/servlet/UiBr...R+VALVE+GASKET
Oops, I lied, $2.79.
Old Mar 25, 2004 | 12:56 AM
i can buy one for 99 cents from partsamerica.com, but it takes a week to get here..............
mdtoren
Aug 23, 2015 12:52 PM
NinjaNife
Aug 23, 2015 11:49 AM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
