Rod and hanger q's....
Old Feb 24, 2001 | 08:11 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Just needed an opinion on which ones to use... i know i played with an extra set i got by bending it, and filing the rods, and it made a world of difference... Basically, i have a carb spacer, the air valve door opens almost 90*, and the exhuast is fully done, ever since i did the air cvlve mod, i have a but of bogging.... when i played with the rods and hangers, most of this went away... any suggestions as to which rods and hangers to try and use??? thanx-
Steve
Old Feb 24, 2001 | 02:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it bogs when they open, try tightening up the air valve spring slightly, like 1/8 turn at a time. If the spring is too loose the valve will just flop open when it should open gradualy in response to the engine's demand for air, which will create a lean condition at the moment you stomp on it.
ICON Motorsports
Old Feb 25, 2001 | 02:54 AM
fb305svs's Avatar
yes this i know- i have adjusted it, to a point, but i know someone had a similiar setup as me and it was something like a h hanger and ar rods??? i dunno, need seggestions here..
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, 1inch carb spacer.
Current Plans: 342 posi disk 10 bolt rear, rebuilt/fixed up tranny with a trans go shift kit, vette servo, and some other goodies...,cowl induction hood, lowering springs, sfc, and new formula wheels, and tires.
Hopeful list- mild 350, headers, and a t56
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
