Need suggestions for suspension mods to prevent this
Old Feb 24, 2001 | 02:45 PM
theformula's Avatar
Check my signature for info on my car. It says I have auburn posi. I do, but it's not installed yet. So my rear is OPEN.
The roads here are dry.
I went through a puddle while exiting Red Lobster . I drove down the road a little then gunned it in 2nd gear. My car started going no where while RPMs were rising. Was this because my tires were a little wet? Do I have to much hp for street tires to be doing this? Is it because of the open rear I have?
What can I do to prevent this?? Any suspension mods?
I really do not want to wreck my car again...
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 24, 2001 | 04:15 PM
The ODB's Avatar
my dodge omni won't even hook up with wet tires. Well, it kinda does.
Old Feb 24, 2001 | 06:23 PM
theformula's Avatar
I don't expect to hook up with wet tires, that is not my goal since I rarely drive in bad weather. I was looking to improving it's performance (braking/handling/accelerating etc) on conditions like this. Not just wet roads. ANy surface
My goal here is a "safer" car. I know it starts with a safer driver (which I am) but there are plenty of morons on the road.
Old Feb 25, 2001 | 05:28 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
one really good but expensive way to get traction is an adj. torque arm like from steve spohn. stiff shocks, poly bushings, lcas etc will help but with a paxton on there how do you even hook up dry? yeah i'd say it was the little moisture left on the tires...
Old Feb 25, 2001 | 05:34 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Put a set of traction bars on that puppy!! I would even recommend possibly getting the Action Lift Bars!!
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.73's....oh joy) :P
Completely Stock
Soon to upgrade to a 350 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Intake, Headman Shorty Headers, Some sort of ported heads (undecided), XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
J-money
Jan 4, 2019 09:45 AM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
