Timing questions
Old Mar 26, 2004 | 11:55 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Timing questions
I had to take the distributer out of my 91 z28, and now i got the timing out of whack. I borrowed a timing light, but i remember i need to disconnect a sensor or wire when i time it. What wire do i disconnect? Can i advance the timing more than manufacturer recommended 6 degrees?
i will be running 93 octane only.
thanx
Old Mar 26, 2004 | 02:31 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
https://www.thirdgen.org/newdesign/t...ngtiming.shtml
The should get you through it..and yes you can set the timing higher than the factory 6 degrees..start with a 2 degree increase to 8
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
