Car Won't Start Need HELP!!
Old Mar 21, 2004 | 09:19 AM
streetphase.com's Avatar
Car: 92 Camaro
Engine: 305tbi
I just installed a new intake manifold, ditched the egr and everything that goes with it including smog pump, and ditched the evac can. Everything is back in the car and the car cranks but does not start. Someone said the distrubutor went in wrong so i tried pointing it to the #1 but it won't drop in itll only drop all the way in one way. Could it be something other than the distributor also is there a way to get my distributor to drop all the way in? Step by step instruction would be awesome if anyone has them how to make sure I'm firing in the right spot. How do you know if the #1 cylinder is where it has to be? Getting close I get my liscense on tuesday and I want to drive this thing so bad...
Old Mar 21, 2004 | 12:36 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
ok,first take out the distributor, put the cyl. # 1 at top dead center on the compression stroke. then you want to ahve the rotor facing the point for cyl. 1 wire. and that will get you close enough to check it qw/ a timing light. to get the dist. in you'll ave to just try it until the oil pump drive sits in the pump right. jsut take it out and put it in rotating it a little bit until it goes in.
Old Mar 25, 2004 | 08:46 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
I don't mean to hijack this post, but I have the same problem. I replaced the cap, rotor, ignition module, and coil. I checked the pickup coil, and it's ok. Even starting at 0*, the thing will not start. Timing's not 180* out or anything like that. any other ideas?
Old Mar 25, 2004 | 09:08 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
are you getting fuel, air, and spark (at the right time)? if so, check your valve lash... mine was too tight!
Old Mar 25, 2004 | 09:14 PM
Car: 89 Formula 350
I've just been informed that I need to check my coil mount for good ground. That seems like the most likely cause. Thanks for the advice. I'll check that too.
Old Mar 26, 2004 | 02:54 PM
Car: 89 Formula 350
Problem fixed.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
