clunking and stalling?
Old Mar 26, 2004 | 05:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok when im going down the highway if i give it gas, it acts like its gonna stall cuz it jerks. also when i push the pedal down or let up in higher rpm range, i hear a clunk each time from rear the tranny is, i believe i need to check my recently installed energy suspension tranny mount. but for the giving it gas and having it jerk on me.. i dunno??
Old Mar 28, 2004 | 11:27 AM
Vader's Avatar
Are you able to tesat your fuel pressure? What is it?
Cleaned the TB? Ignition system good and reliable? EGR valve not hanging up on you, is it?
Old Mar 28, 2004 | 05:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
when u mean clean the TBI? what do you mean? i used that stuff to clean out all the grease build up. that made it look nice, i used fuel injector cleaner to maybe clean out the injectors. the cap is new, the rotor, i cleaned up, wires look fine, had to replace one though cuz it burned, spark plugs are 2 days old.
EGR valve.. what do you mean hanging up on me?
also, the clunk was just a loose crossmember bolt.
but i still have to deal with the jerking of my car at highway speeds.
how can i test my fuel pressure?
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
Ragtop Man
Sep 12, 2015 12:23 AM
